Macintosh Performa 460
The Macintosh Performa 460 is a desktop Macintosh sold by Apple through consumer retail shops. It is the Macintosh LC III+ under a Performa name: a 33 MHz version of the Macintosh LC III.[1][2] The Performa 466 and 467 are the same machine with a 160 MB hard drive and the Performa Display Plus.[2] Low End Mac records that the 460 replaced the Performa 450 in October 1993.[3] EveryMac describes a new case for the 460, with a curved front, a more rounded foot and finger indentations above and below the floppy slot; the dimensions Apple gives are unchanged.[1][2]
Apple gives the introduction date as October 18, 1993, with System 7.1P3 and System Enabler 308 as the original system software.[4] EveryMac gives a US price of US$1,300, discontinuation on November 1, 1993, order number M2156LL/A and model number M1254.[1]
[edit | edit source]| Item | Figure |
| Processor | Motorola 68030 at 33 MHz; 32-bit data bus; coprocessor socket |
| RAM | 4 MB on board; one 72-pin SIMM socket for 1, 2, 4, 8, 16 or 32 MB SIMMs of 80 ns or faster; 36 MB maximum |
| ROM | 1 MB |
| VRAM | 512 KB on the board; one VRAM SIMM socket takes a 256K SIMM for 768 KB |
| Floppy drive | Apple SuperDrive, 1.4 MB: manual-insert (Service Source), auto-inject (technical specifications) |
| Hard drive at introduction | 80 MB SCSI |
| Bundled monitor | Performa Display |
| Ports | One ADB, two serial (printer and modem, mini DIN-8), SCSI DB-25, DB-15 video, sound in and out |
| Expansion | One 114-pin processor-direct slot for 020/030 cards |
| Electrical | 100–240 VAC, 47–63 Hz, automatically configured; 50 W maximum (technical specifications) |
| Size and weight | 3.0 × 12.2 × 15.0 in (7.7 × 31.0 × 38.2 cm); 8.8 lb (4.0 kg) |
Sources: Apple's technical specifications, the Performa 400 Series Service Source, pp. 3–15, and the Macintosh LC III Developer Note, p. 2.[4][2][5] The Service Source prints no maximum-power figure for the 460, 466 and 467.
The coprocessor socket is a PLCC socket for a 68882; no FPU is fitted as standard.[4][5] With the on-board 512 KB of VRAM the machine shows 256 colours at 640 × 480 and 832 × 624; with 768 KB it shows thousands. A 512K VRAM SIMM fits the socket, but only 256K of it is used.[4] The processor-direct slot has a power budget of 4 W.[5]
The PRAM battery is a 3.6 V lithium cell, Apple part 742-0011; Apple says to replace it below 3.0 V. The power supply is part 661-1733, shared with the whole LC family.[4][2]
Known faults
[edit | edit source]- Leaking surface-mount electrolytic capacitors on the logic board and in the power supply. The board list is on Macintosh LC III+ Capacitor Replacement Guide.
- C22 on the LC III logic board, the 47 µF capacitor on the −5 V rail, is printed and fitted the wrong way round at the factory. Doug Brown's article treats the Performa 460, 466 and 467 as the same design. Serial-port faults after a recap point there.[6]
- A flat PRAM battery: Apple's charts for this family put "Check batteries" first for "No video" and in the no-power entries.[2]
See Macintosh Performa 460 Troubleshooting, which applies to all three models, and Macintosh LC III+ Troubleshooting.
Service documentation
[edit | edit source]Apple covers the Performa 460 in the Macintosh Performa 400 Series Service Source. The Macintosh LC III Developer Note describes the hardware.[2][5]
[edit | edit source]- Macintosh LC III+
- Macintosh Performa 460 Troubleshooting
- Macintosh LC III+ General Maintenance
- Macintosh LC III+ Capacitor Replacement Guide
- Macintosh Performa 466
- Macintosh Performa 467
[edit | edit source]- ↑ 1.0 1.1 1.2 EveryMac, "Macintosh Performa 460 Specs".
- ↑ 2.0 2.1 2.2 2.3 2.4 2.5 2.6 Apple Computer, Service Source: Macintosh Performa 400 Series (1995), File:Performa 400 series.pdf; see Macintosh Performa 400 Series Service Source. Page numbers are PDF pages.
- ↑ Low End Mac, "Apple's Performa Line, 1992 to 1997".
- ↑ 4.0 4.1 4.2 4.3 4.4 Apple, "Macintosh Performa 460: Technical Specifications".
- ↑ 5.0 5.1 5.2 5.3 Apple Computer, Macintosh LC III Developer Note (1993), p. 2, File:Macintosh LC III Developer Note.pdf; see Macintosh LC III Developer Note. The note describes the 25 MHz LC III.
- ↑ Doug Brown, "The capacitor that Apple soldered incorrectly at the factory", 26 November 2024.
