Macintosh Quadra 700 General Maintenance
Maintenance guidance for the Macintosh Quadra 700. The Quadra 700 uses the IIcx/IIci enclosure stood on end, and Apple services all three machines in one manual, so much of the service data below is shared with those models.[1]
Opening the Machine
Apple's procedure is one screw, not a set of clips: remove the single Phillips screw at the rear, then pull up on the tabs and lift the cover until it comes free at the front.[1] The case is designed to come apart without tools beyond that — the power supply, drive mount and logic board all release by hand.
Unplug the mains lead before opening it. The supply's primary side sits at mains potential and its reservoir capacitors hold a charge after the machine is switched off.
Regular Cleaning
Internal
- Power off and disconnect everything before opening.
- Blow dust off the logic board, supply and fan with compressed air.
- Clean the fan blades with a soft brush; listen for bearing rumble while the machine runs.
- Check around the battery holder and the I/O connectors for corrosion.
- Check the floppy mechanism for debris and old grease.
External
- Case: damp cloth and mild detergent; isopropyl alcohol on stubborn marks.
- Clear the ventilation slots — Apple's own troubleshooting lists blocked side and top vents as a cause of intermittent shutdowns, because the thermal protection circuit trips. After 30 to 40 minutes the machine will restart normally.[1]
- Ports: dry cotton bud only.
For plastic yellowing see Retrobrite.
Keyboard and Mouse
- Disconnect before cleaning.
- Invert the keyboard and shake gently to clear debris; clean keycaps with isopropyl alcohol.
- On an ADB mouse, remove the ball, clean the rollers with isopropyl alcohol and wash the ball with soap and water, then dry it fully before refitting.
PRAM Battery
Apple's check for this machine: set the voltmeter to the 10 V DC range, measure across the cell, and replace it if it reads below 2.8 V.[1]
That threshold is specific to the Quadra 700, IIcx and IIci. Apple specifies 3.2 V for the later Centris 650, 660AV, Quadra 800, 840AV and Quadra 900/950, and 3.0 V for the all-in-one Performa 5000 machines, which use a different battery entirely. Do not carry a figure across from another model.
To reach the cell, Apple has you remove the cover, the power supply and the drive mount first. The cell sits in a holder with a latched cover: prise the latch at the end of the holder open with a small flat-blade screwdriver, lift the cover off, and lift the cell out. It is not soldered in and has no tabs.[1]
Apple's symptom charts list a battery check among the first steps for a machine that is completely dead — no fan, no LED — and for one that shuts down intermittently, because the cell is part of the soft-power circuit.[1]
If the cell has leaked
- Remove it at once.
- Clean the residue with isopropyl alcohol, then check continuity on every trace running out from under the holder.
- Corrosion spreads under the solder mask; what you can see is usually smaller than what has happened.
See Battery Explosion, Capacitor or Corrosion Damage for cleaning and trace-repair technique, and Battery Refurbishment.
Capacitors
The Quadra 700 logic board is populated with tantalum rather than surface-mount aluminium electrolytic capacitors, so the leaking-electrolyte problem that defines this era of Macintosh repair does not apply to it.[2][3]
Tantalums have their own failure mode — they fail short rather than open, sometimes noisily — so a rail that measures as a short to ground with the supply disconnected is worth investigating. But there is no case for preventive recapping of this logic board.
The power supply is a different matter; it is a normal early-1990s switcher full of aluminium electrolytics. See Macintosh Quadra 700 Capacitor Replacement Guide.
Connectors and Sockets
Check and clean with a contact cleaner such as DeoxIT D5, allowing it to dry fully before powering on:
- 30-pin DRAM SIMM sockets — oxidation here produces start-up chimes and crashes that look like a dead logic board.
- VRAM SIMM sockets. Apple's video symptom chart lists "Quadra 700: replace VRAM SIMMs" as an early step for a dark screen, so reseating and cleaning them is worth doing first.[1]
- ROM SIMM socket. Apple specifies 1 MB of ROM soldered to the board with a ROM SIMM socket also available.[1]
- NuBus and PDS connectors.
- ADB and serial connectors.
- The power supply connector on the logic board — look for discoloured or corroded pins.
SCSI Termination — a Self-Inflicted Fault
Every Quadra 700 shipped without an internal hard drive left the factory with a SCSI termination block fitted to the logic board's SCSI connector. Once you install an internal hard drive, that block must be removed.[1]
Leaving it in place double-terminates the internal bus and produces exactly the symptoms people blame on a failing drive or a bad cable: drives that appear and disappear between boots, data errors, and external devices that refuse to mount. It is the first thing to check on any Quadra 700 with an unexplained SCSI problem, particularly one that has had a drive retrofitted.
Power Supply
Apple's electrical specification: 100–240 V AC, automatically configured, 50–60 Hz single phase; 130 W maximum, 90 W continuous, not including monitor power.[1] There is no voltage selector to set wrongly.
The Quadra 700 uses the same physical supply as the IIci — Apple part number 614-0004, built by Astec as model AA15831 or by GE as model 9T89Y5005G11. The rating plate gives:[4]
| Rail | Rated current |
| +5 V | 12 A |
| +12 V | 1.5 A |
| −12 V | 1.0 A |
| +5 V trickle | 1 mA continuous |
Apple publishes no rail tolerance band and no power-supply adjustment procedure for this machine. There is no voltage-adjustment section anywhere in the Service Source and no potentiometer to turn. If a rail is visibly wrong, the fault is in the supply, not in a trim setting.
The useful measurement is the +5 V trickle rail. It is live whenever the machine is plugged in, and it feeds the soft-power circuit. On a machine that is completely dead: trickle present means the primary side is running and the fault is downstream; trickle absent means the fault is in the mains input, the primary switcher or the standby circuit.
Apple's symptom charts send the following to the power supply:[1]
- Dead machine — black screen, fan not turning, LED not lit (after checking cables, the mains lead and the battery).
- Clicking, chirping or thumping noises.
- Intermittent shutdowns that are not explained by blocked vents or a flat battery.
Thermal Management
The machine relies on one fan. Replace it if it runs slowly, intermittently or noisily — bearing rumble is the warning. Keep the side and top vents clear: Apple documents the thermal protection circuit shutting the machine down when they are obstructed, with a 30 to 40 minute recovery.[1]
Standing the case vertically, as Apple intended for this model, also helps convection through the same vents.
Related Pages
- Macintosh Quadra 700
- Macintosh Quadra 700 Troubleshooting
- Macintosh Quadra 700 Capacitor Replacement Guide
- Recommended Tools
- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 Apple Computer, Macintosh IIcx/IIci/Quadra 700 Service Source — hosted on this wiki as File:Quadra_700.mac_iicx.iici.pdf. Chapters used here: Specifications (Memory, I/O Interfaces, Sound and Video, Electrical), Troubleshooting (Symptom Charts), Take Apart (Cover) and Additional Procedures (Battery Verification, Battery Replacement, SCSI Termination).
- ↑ Andrew Cunningham, "Working from home at 25MHz: You could do worse than a Quadra 700", Ars Technica, 11 December 2020. Secondary source for the Quadra 700 logic board using tantalum capacitors.
- ↑ 68kMLA forum thread "Mac II Series vs Quadra 700". Secondary source: two members independently state that the Quadra 700 main logic board was built with tantalum capacitors and that leakage problems on it are effectively non-existent, in contrast to the IIci.
- ↑ 68kMLA forum thread "Compact Desktop Power Supply Capacitor Lists (by make and model)", posts by jessenator, Fizzbinn and Franklinstein. Secondary source: rating-plate readings and capacitor lists taken from members' own supplies. Source for the Apple part number 614-0004, the Astec and GE model numbers against it, and the rail current ratings quoted here.
