Macintosh SE/30
Revision as of 18:17, 23 September 2026 by Josh (talk | contribs) (Rebuilt against Apple SE/30 Service Source + Guide to the Macintosh Family Hardware: release date was 16 January 1986 (wrong; 19 January 1989), CPU 16.667MHz -> 15.667MHz, ROM 512KB -> 256KB, weight 19.5lb -> 21.5lb, RAM 128MB claim qualified against Apple 32MB; DELETED fabricated memory map, ROM module table, SCSI/sound path detail, JP13 and chess-tone easter egg; pseudo-slot video explained from Apple ch.12; chip location map from the hosted 050-0253-01 redraw; refs and reflist)
Macintosh SE/30
Macintosh SE/30
TypePersonal computer
Released19 January 1989
Discontinued21 October 1990
Intro priceUS$4,400 (US$4,900 with hard disk)
CPUMotorola 68030 @ 15.667 MHz
Memory1 or 4 MB, expandable to 32 MB (Apple); 128 MB with uncertified 16 MB SIMMs
Storage1.4 MB floppy drive; optional 40 or 80 MB internal SCSI hard disk
Display9-inch monochrome CRT, 512 ร— 342 pixels
SoundApple Sound Chip: four-voice wavetable, stereo sampling
Graphics512 ร— 342 monochrome; separate 64 KB video RAM and 8 KB video declaration ROM
ROM256 KB
FPU / coprocessorMotorola 68882
Ports / interface2 ร— ADB; DB-19 external floppy; DB-25 SCSI; 2 ร— RS-232/RS-422 serial; stereo sound out
Expansion030 direct slot, 120-pin Euro-DIN, full 32-bit address and data
Power120โ€“240 V AC, automatically configured, 48โ€“62 Hz, 75 W maximum
Dimensions13.6 in H ร— 9.6 in W ร— 10.9 in D (34.5 ร— 24.4 ร— 27.6 cm)
Weight21.5 lb (9.75 kg)
OS / FirmwareSystem 6.0.3 โ€“ System 7.5.5
PredecessorMacintosh SE
SuccessorMacintosh Classic II
CodenameGreen Jade, Fafnir, Oreo
Model no.M5119
The Macintosh SE/30 was introduced on 19 January 1989: a Macintosh IIx in a compact case. It is by a wide margin the most capable of the compact Macintoshes โ€” a 68030 with a memory management unit, a 68882 floating-point unit as standard, eight SIMM sockets, a full 32-bit processor-direct slot and the first 1.4 MB SuperDrive fitted to a compact.[1][2]
It is also the compact most likely to arrive dead, because of the surface-mount capacitors on its logic board. Read Macintosh SE/30 General Maintenance before powering up a machine that has been in storage.
Apple's own specification pages.[2]
Item Specification
CPU Motorola 68030, 15.667 MHz, 256-byte instruction and data caches, built-in paged memory management unit
Coprocessor Motorola 68882 floating-point unit
RAM 1 or 4 MB, expandable to 32 MB
ROM 256 KB
PRAM 256 bytes, CMOS custom chip with a long-life lithium battery
Floppy 1.4 MB
Hard disk Optional 40 or 80 MB
Expansion One 030 direct slot, full 32-bit address and data lines, 120-pin Euro-DIN
SCSI 50-pin internal, DB-25 external
ADB Two ports
Serial Two RS-232/RS-422 ports, 230.4 kbaud maximum
Sound Apple Sound Chip (ASC): four-voice wavetable synthesis and a stereo sampling generator; mixed to mono at the internal speaker
Video 9-inch diagonal, 512 ร— 342 bit-mapped. Colour QuickDraw in ROM supports grey-scale and colour cards in the 030 slot
Line voltage 120โ€“240 V AC RMS, automatically configured
Frequency 48โ€“62 Hz, single phase
Maximum power 75 W
Dimensions 13.6 ร— 9.6 ร— 10.9 in (34.5 ร— 24.4 ร— 27.6 cm)
Weight 21.5 lb (9.75 kg)
Video: why the SE/30 is different
The screen looks like a Macintosh SE screen but the hardware behind it is not. The SE/30's logic board carries a separate 64 KB video display RAM and a separate 8192-byte video declaration ROM, mapped at $FE00 0000 โ€” the address space used by expansion slot $E in the Macintosh II family. Apple calls this pseudo-slot video: the built-in display pretends to be a Macintosh II video card so that the SE/30 can share the system ROM used by the other 68030 machines.[3]
The practical consequence: no main memory is reserved for the display. The video buffer is independent of the SIMMs, so no memory configuration is better or worse for video.
Memory
Eight 30-pin SIMM sockets in two banks of four, 120 ns or faster, eight chips per module, banks filled completely, larger modules in bank A. Apple's published maximum is 32 MB; 16 MB modules take it to 128 MB but were never certified by Apple. Full rules: Macintosh SE/30 Memory Upgrade Guide.[3][2][1]
Anything above 8 MB requires 32-bit addressing, which the SE/30's ROM does not provide by itself โ€” Mode32 or an equivalent enabler is needed.[1]
Service manual and schematics
Apple service manual
All of the Apple service manuals are on the Apple Service Source page.
Logic board and analogue board
Macintosh SE/30 PCB images
Logic board Analogue board
Macintosh SE/30 logic board
File:MacintoshSE30 LogicBoard Schematic.pdf
Macintosh SE/30 analogue board
Fan and CRT board
A KiCad recreation of Apple engineering drawing 050-0253-01, released under the MIT licence, is hosted here and is the most usable source for tracing corroded traces: File:Macintosh SE30 Logic Board Schematic Redraw 050-0253-01.pdf. Its pin matrices identify the major devices โ€” UK8 CPU, UI5 FPU, UI8 GLUE, UK12/UK11 VIA1/VIA2, UJ11 SWIM, UI12 SCSI, UG12 SCC, UK6 video ROM, UC6/UC7 VRAM, J13 PDS.[4]
Maintenance, capacitors and troubleshooting
There is no power-supply voltage adjustment on the SE/30. Apple's Adjustments chapter covers the yoke and the video only, and publishes no rail tolerances.[2]
A Sad Mac showing error code 00000001 over any value points at the ROM SIMM rather than at RAM โ€” reseat it before suspecting anything else.[5] See Sad Mac Error Codes and the Sad Mac Decoder.
  1. โ†‘ 1.0 1.1 1.2 Low End Mac, Mac SE/30 tech specs (secondary source, used for dates, prices, codenames and the 128 MB memory ceiling).
  2. โ†‘ 2.0 2.1 2.2 2.3 Apple Computer, Macintosh SE/30 Service Source โ€” Specifications, Troubleshooting, Take Apart, Adjustments and Additional Procedures chapters. Hosted on this wiki: File:Macintosh se.30.pdf.
  3. โ†‘ 3.0 3.1 Apple Computer, Guide to the Macintosh Family Hardware, 2nd edition, Addison-Wesley, 1990 โ€” Chapter 12 "Displays", pp. 408โ€“409 (pseudo-slot video, 64 KB video RAM, declaration ROM) and Chapter 5 "Memory", pp. 208โ€“211 (SIMM rules).
  4. โ†‘ Macintosh SE/30 Logic Board Schematic Redraw, KiCad recreation of Apple engineering drawing 050-0253-01, MIT licence. Hosted on this wiki: File:Macintosh SE30 Logic Board Schematic Redraw 050-0253-01.pdf.
  5. โ†‘ Larry Pina, The Dead Mac Scrolls, Peachpit Press, 1992, "Mac SE and SE/30" chapter. Hosted on this wiki: File:The Dead Mac Scrolls 1992.pdf.
