Macintosh Centris 660AV General Maintenance
Proper maintenance is essential to extending the lifespan and ensuring reliable operation of your Macintosh Centris 660AV (also sold as the Quadra 660AV). The following sections provide guidance on cleaning, battery management, and preventative care.
Regular Cleaning
Internal Cleaning
  • Power off and unplug the computer; allow it to sit for at least 15 minutes
  • Remove the top cover by pressing the release tabs on either side
  • Use compressed air to remove dust from the logic board, power supply, and fan
  • Pay attention to the ventilation slots and fan area
  • Clean the floppy drive heads with a cleaning disk if read errors occur
  • Inspect all socketed chips for corrosion or oxidation
External Cleaning
  • Wipe the case with a slightly damp, lint-free cloth
  • Clean the ventilation grilles with a soft brush or compressed air
  • Use isopropyl alcohol for stubborn marks on the plastic case
  • Do not spray liquids directly onto the computer
Keyboard and Mouse Cleaning
  • Remove keycaps and clean underneath with compressed air
  • Wipe keycaps with isopropyl alcohol
  • Clean the mouse ball and rollers (if applicable) with isopropyl alcohol
  • For ADB mice, inspect the cable for damage near the connector
PRAM Battery Handling
The Centris/Quadra 660AV uses a 3.6V half-AA lithium battery for PRAM.
Best Practices
  • Replace the battery every 3โ€“5 years, even if the computer still boots correctly
  • Always use a quality replacement (Maxell, Tadiran, or equivalent)
  • Never attempt to recharge the lithium battery
  • A dead battery can cause loss of built-in video (see Apple KB TA35928)
Cleaning Battery Leakage
If the PRAM battery has leaked:
  • Remove the battery immediately and dispose of it properly
  • Clean affected areas with white vinegar to neutralize the electrolyte
  • Follow up with isopropyl alcohol to remove residue
  • Inspect nearby traces and components for corrosion damage
  • Use a fiberglass pen or DeoxIT to clean corroded contacts
Connector and Socket Corrosion
Key Areas to Check
  • SIMM sockets โ€“ Clean contacts with DeoxIT or isopropyl alcohol
  • PDS/NuBus slot โ€“ Inspect for oxidation on contacts
  • Power connector โ€“ Check for discoloration or heat damage
  • ADB ports โ€“ Look for bent pins or corrosion
  • Serial ports โ€“ Verify all pins are straight and clean
  • Video connector โ€“ Inspect for damaged or corroded pins
Apply DeoxIT D5 to all socketed connections and card edge connectors during maintenance.
Common Failure Points
Power Supply
The internal power supply can accumulate dust on the filter mesh near the fan. A "bad" power supply may be restored by clearing this dust buildup.
Capacitor Health
The logic board contains electrolytic capacitors that can leak or fail after 25+ years. See Macintosh Centris 660AV Capacitor Replacement Guide for detailed information.
Symptoms of capacitor failure:
  • Machine fails to boot or boots intermittently
  • Audio distortion or no sound
  • Visible electrolyte residue on the logic board
  • Corroded traces near capacitors
PRAM Battery Damage
Dead or leaking PRAM batteries are a common failure point. Symptoms include:
  • Loss of date/time settings
  • Loss of display settings
  • Complete loss of built-in video
  • Failure to boot
Floppy Drive
Early Centris 660AV units have auto-inject floppy drives that can fail. Later Centris and all Quadra 660AV units use manual-inject drives. Common issues:
  • Dirty or worn heads
  • Belt deterioration (auto-inject models)
  • Mechanical eject failure
Logic Board Socket Oxidation
The 660AV has socketed components that can develop oxidation over time:
  • CPU socket (if socketed)
  • ROM SIMM socket
  • RAM SIMM sockets
Regular cleaning with DeoxIT helps prevent contact issues.
Voltage Adjustment and Power Checks
The 660AV power supply provides the following rails:
Rail Nominal Acceptable Range
+5V 5.00V 4.85V โ€“ 5.15V
+12V 12.0V 11.9V โ€“ 12.7V
Measure voltages at the power connector with the machine running under normal load. Voltages outside these ranges may cause instability.
