Apple Lisa Troubleshooting
Revision as of 19:27, 1 October 2026 by Josh (talk | contribs) (Update links to Service Support Training Programs LaserWriter Technical Procedures Jan 1985 after page move)
Apple Lisa
Apple's troubleshooting procedures for the Apple Lisa, Lisa 2 and Macintosh XL are in the Lisa Troubleshooting Guide, part of its Level I technical procedures. They work by module swapping: each procedure lists the modules to replace, in order.[1]
Before you start
  • Remove the I/O board battery pack from any machine that has been in storage; see Battery pack.
  • The CRT anode holds about 15,000 V DC after power-off; see CRT Discharge Procedure.[1]
  • Remove expansion cards and other attachments and press the reset button before diagnosing start-up faults. If the fault goes away, refit the cards one at a time, restarting after each, until it returns.[1]
  • Apple's first troubleshooting step clears parameter memory: remove the back panel and switch SW1 on the I/O board off for about 5 seconds, then back on. This erases the preference settings. The Lisa 2/10 I/O board has no switch.[1]
Normal start-up
Apple's description of a healthy start-up:[1]
  1. The on/off lamp lights.
  2. The Lisa is silent for about 3 seconds, then gives a single click.
  3. About 30 seconds after power-on, as the picture tube warms up, four icons appear for the CPU, I/O, memory and expansion cards, each highlighted in turn as the boot ROM tests it.
  4. A card that fails is shown with a large X through its icon and error tones sound; or an error icon and error code are displayed.
If the lamp does not light, go to the power repair procedure. If there is no click or unexpected tones sound, press reset on the back panel and, if it still will not boot, go to the start-up repair procedure. If there is no picture after 30 seconds, go to the video repair procedure.[1]
On the Lisa 2 and Macintosh XL the boot ROM and I/O ROM codes appear in the upper right corner of the screen after the icons have been tested: H and A8 on a Lisa 2 or 2/5, H and 88 on a Macintosh XL, with 3A in place of H once the Screen Modification Kit is fitted.[1]
Power repair procedure
Apple's order for a Lisa with power problems:[1]
  1. Check the cables and power cord.
  2. Check that the front and back panels are fitted securely so the interlock switches are closed.
  3. Check the wall outlet.
  4. Check the ribbon cable from the motherboard to the soft-switch/keyboard assembly.
  5. Check there is 2 inches (5 cm) of ventilation space around the Lisa.
  6. If the Lisa may have overheated, unplug it and let it cool for an hour.
  7. Swap modules in this order: power supply, I/O board, soft-switch/keyboard assembly, front interlock switch, disk drive to card cage connector, motherboard, video board.
The supply's outputs and their permitted variation are tabulated on Apple Lisa General Maintenance, and the capacitor lists are on Apple Lisa Capacitor Replacement Guide.
Start-up repair and error tones
Start-up symptoms and error tones[1]
Symptom Probable failure, in Apple's order
Incorrect or no video, no clicks, no error tones CPU; I/O; video (go to video repair); motherboard
No clicks, and the display shows the boot ROM test found no problems Speaker connections; I/O; speaker
Blank screen with the start-up clicks Go to video repair
Tones: Lo CPU; memory 1; memory 2
Tones: Lo, Lo Memory 2; CPU
Tones: Lo, Hi Card cage (swap boards one at a time)
Tones: Lo, Lo, Hi CPU
Tones: Lo, Hi, Lo I/O
Tones: Hi, Hi, Hi Peripheral card
Tones: Lo, Hi, Hi Memory 1; memory 2
Tones: Hi, Lo, Lo Expansion boards
Tones: Hi, Lo, Hi Keyboard
Tones: Hi, Hi, Lo Keyboard or mouse disconnected
Start-up error codes
Start-up error codes and Apple's replacement order[1]
Code Apple's description Replace, in order
22, 23, 25, 38 Unable to clamp, read or unclamp diskette; no boot file on diskette See the start-up messages for the bad diskette icon
39 Disk controller timeout I/O board, CPU board, motherboard
40 MMU CPU board
41 CPU selection logic CPU board
42 Video circuitry CPU board
43 Parity circuitry CPU board, memory board 1, memory board 2, motherboard
44 NMI error CPU board, I/O board, motherboard
45 Bus error I/O board, CPU board, motherboard
46 Address error CPU board, memory board 1, memory board 2
47 Exception CPU board, motherboard
48 Illegal instruction CPU board, memory board 1, memory board 2
49 1010 or 1111 trap CPU board, memory board 1, memory board 2
50 COPS VIA I/O board, CPU board, motherboard
51 Parallel port VIA I/O board, CPU board, motherboard
52 I/O board COPS I/O board
53 Keyboard COPS Keyboard, I/O board, keyboard cable, motherboard
54 Clock error I/O board
55, 56 RS-232 port A, port B I/O board
57 Disk controller I/O board, disk drive, disk drive cables, CPU board, motherboard
58 I/O board access I/O board, CPU board, motherboard
59 I/O board COPS code I/O board
60-69 I/O or keyboard error Keyboard, I/O board, keyboard cable, motherboard
70, 71 Memory data, memory parity The memory board named by the icon displayed
75 Boot failure See the start-up messages for the icon shown
80-85 ProFile errors See the start-up messages for the bad ProFile icon
90-93 Expansion card errors See the start-up messages for the bad expansion card icon
Codes 43, 46, 48 and 49 point at the CPU board or a memory board; Apple's order is the CPU board first. The Lisa has no SIMMs: memory is on two plug-in boards (661-93105), and both must be fitted to run the diagnostic diskette.[1] LisaTest starts at customer level; APPLE-SHIFT-S switches it to service level, where individual modules can be tested.[2]
Video repair
Apple opens its video repair procedures with a warning: "If you have never been taught how to adjust and replace the Lisa video modules do not attempt to do video repairs." The adjustments are made with the power on.[1]
Apple video repair table (extract)[1]
Symptom Fixes, in Apple's order
A sizzling noise from the Lisa Replace power supply; adjust brightness; adjust contrast (hardware); replace video board; replace flyback
Power supply trips (turns off and on) Adjust brightness; adjust contrast (hardware); replace power supply; replace video board; replace flyback
Blank screen, CRT filament not lit Check connections; adjust brightness and contrast; replace video board, CPU board, I/O board, power supply, flyback, CRT, motherboard
Blank screen, CRT filament lit Check connections; set the hardware contrast to mid-range; replace power supply, video board, CRT, flyback, CPU board, motherboard
Unable to adjust brightness Replace power supply, video board, CRT, CPU board
Unable to adjust contrast by software Replace I/O board, CPU board, video board; check the keyboard with keyboard diagnostics; replace motherboard
Blurred screen Adjust focus
Unable to adjust focus Replace power supply, video board, CRT; check connections; replace flyback
Rolling screen Adjust vertical hold
Small picture Adjust height and width; adjust brightness and contrast; replace video board, flyback
Only a horizontal line on screen Lower brightness and contrast; replace video board, CRT
Let the Lisa warm up for 10-15 minutes before making video adjustments.[1]
Mouse, keyboard and hard disk
Apple's mouse, keyboard and hard disk procedures (summary)[1]
Symptom Apple's procedure
No cursor Remove and reinsert the mouse plug; replace the mouse
Mouse movement or button does nothing Reinsert the mouse plug; try the keyboard. If the keyboard works, replace the mouse; if neither works, replace the I/O board, CPU board, motherboard
Pointer moves only vertically or only horizontally Reinsert the mouse plug; replace the mouse; replace the I/O board
No keyboard input Reinsert the keyboard plug; try the mouse. If the mouse works, replace the keyboard. If neither works, press the power button: if the Lisa turns off, reseat and then swap the I/O board, CPU board and motherboard; if it does not, go to the system hang procedure
Some keys do not work Replace the keyboard
ProFile or internal hard disk error icon at boot Check the disk is attached (never connect or disconnect a ProFile with either unit switched on). Switch off, power the disk up and watch its ready light: it flickers during the self-check and then stays on. If it does not, replace the disk. Test it with LisaTest
A Lisa that ignores all input can usually be recovered without losing work: try the keyboard equivalents, press the disk-release buttons, press the on/off button once, and only then press reset. If it still hangs, unplug it, switch on again and listen for error tones.[1]
Battery pack
A leaking I/O board battery pack
The I/O board's 4.8 V NiCd pack leaks with age and corrodes the I/O board around it.[3] Remove it before powering up a stored machine. A Lisa that loses its clock with a good pack may just have the battery switch off: Apple's set-up procedure has the switch set to ON, toward the left.[1]
Twiggy drives (Lisa 1)
The original Lisa has two 5.25-inch FileWare ("Twiggy") drives, 871 KB formatted each; Apple's drive module part number is 661-93110.[4][2] The Computer History Museum describes the in-house Twiggy drive as unreliable; the Lisa 2 replaced it with a single Sony 3.5-inch drive.[5]
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 Apple Computer, Apple Service Technical Procedures: Lisa/Macintosh XL (Lisa Level I Technical Procedures, #072-0085, pages revised to June 1987): Lisa 1.0 Set-up §C p. 2.6; Lisa Troubleshooting Guide pp. 6.3-6.4 (troubleshooting steps), 6.11 (power repair), 6.12-6.13 (start-up repair and error tones), 6.19-6.21 (video repair), 6.24-6.28 (mouse, system hang, hard disk and keyboard); Lisa 2 Video Take-Apart p. 3.3; Lisa Video Adjustments p. 4.4; Diagnostics pp. 5.2-5.2.1; Lisa/Macintosh XL Troubleshooting pp. 6.16-6.18 (error codes). Hosted as Apple Service Technical Procedures Lisa/Macintosh XL (PDF).
  2. ↑ 2.0 2.1 Apple Computer, Lisa Level 1 Technical Procedures, #072-0085, March 1985: Diagnostics (LisaTest service level); Illustrated Parts Lists. Hosted as Apple Lisa Level 1 Technical Procedures Mar85.
  3. ↑ Apple Computer, drawing 050-4008 rev. K, "Schematic, System I/O, Lisa", sheet 5. Hosted as File:Apple Lisa I-O Board Schematic 050-4008-K.pdf.
  4. ↑ Apple Computer, Lisa Owner's Guide (1983), Appendix 5, "Hardware Specifications", pp. 119-120. Hosted as Apple Lisa Owners Guide 1983.
  5. ↑ Hansen Hsu, "The Lisa: Apple's Most Influential Failure", Computer History Museum, January 19, 2023.
