Macintosh LC General Maintenance
This page covers routine care for the original Macintosh LC (logic board 630-0309, 1990). The chassis, power supply, battery and take-apart procedure are shared with the Macintosh LC II, Macintosh LC III, Macintosh LC III+, Macintosh LC 475 and Macintosh Quadra 605; the logic boards are not.
Every figure below comes either from Apple's own Service Source for the LC series and Quadra 605 or from Apple's Macintosh LC Developer Note, both hosted on this wiki. Where a figure is in neither, it is not given.[1][2]
What this machine is
| Item | Figure |
| Processor | Motorola 68020 at 16 MHz, on a 16-bit data bus |
| DRAM | 2 MB standard, expandable to 10 MB (100 ns or faster SIMMs) |
| ROM | 512 K |
| VRAM | 256 K, upgradable to 512 K |
| Expansion | 96-pin processor-direct slot for an 020 direct-slot card |
| Sound | Monaural 8-bit input at 11 or 22 kHz; monophonic 8-bit generator feeding the same signal to both channels |
| Dimensions | 3.0 ร 12.2 ร 15.0 in (7.7 ร 31.0 ร 38.2 cm) |
| Weight | 8.8 lb (4.0 kg) |
All of the above is Apple's.[1] Two consequences are worth knowing before you start diagnosing:
- The 10 MB ceiling is real. You can fit 12 MB and the machine will still only address 10. That is Apple's own figure, not a fault and not something a different SIMM will fix.[1]
- There is no stereo output. Apple specifies a monophonic generator feeding both channels on the LC, LC II and LC III. Only the LC 475 and Quadra 605 in this family are genuinely stereo.[1]
Every "pizza box" machine in this family โ LC, LC II, LC III, LC III+, LC 475 and Quadra 605 โ takes the same power supply, which Apple lists as a single service part, 661-1733.[1] It is a universal auto-ranging switch-mode unit covering 100โ240 VAC, so there is no voltage selector to set wrongly and no separate 120 V and 230 V board to confuse.[1]
| Item | Figure |
| Line voltage | 100โ240 VAC, automatically configured |
| Frequency | 47โ63 Hz |
| Maximum power, LC | 50 W, monitor excluded |
Note what that figure is: the machine's maximum consumption, not the supply's rating. The same 661-1733 supply is fitted to a 50 W LC and a 26 W Quadra 605.[1]
Apple publishes no rail tolerance and no power-supply adjustment procedure for this machine. The Service Source carries no acceptable-range table for the +5 V, +12 V or โ5 V rails and no trimmer adjustment; every power fault in the symptom charts ends in "Replace power supply".[1] The "+5 V 4.85โ5.15 V / +12 V 11.9โ12.7 V" table that circulates on pages of this era is Apple's Macintosh Plus procedure โ genuine there, where it uses voltage test cable 077-0135 on the external floppy port โ copied onto machines it was never written for. It has been removed from this page rather than reproduced.
What you can do instead is compare against a known load. With the machine running, each rail at the logic-board power connector should sit close to its nominal value and should not move when a drive spins up. A rail that is visibly low, or that sags under load, points at the supply. A rail that measures as a short to ground with the supply disconnected points at the logic board.
Recapping it
You are allowed to open this supply โ tired electrolytics in it are one of the commonest reasons one of these machines will not start. Understand what is live inside first. It is fed straight from the mains, so with the cover off and the lead in, the fuse, input filter, bridge rectifier and bulk capacitor all sit at mains potential. The bulk capacitor charges to roughly the peak of the incoming waveform โ about 170 V on 120 V mains, about 340 V on 230 V mains โ and holds a useful fraction of that after the plug comes out. Unplug, wait, then measure across the bulk capacitor and confirm it reads a few volts before a tool goes near the primary side.
Apple bought this supply from several vendors and their capacitor complements differ, so read the maker's label before ordering parts. The per-variant lists are on Macintosh LC Capacitor Replacement Guide.
Removing it: disconnect the power supply cable from the logic board, release the two latches that hold the front end of the supply to the bottom case, and lift it out.[1]
PRAM battery
Apple's part is a 3.6 V lithium half-AA cell, part number 742-0011, in a clip-in holder on the logic board. It appears under that number in the exploded view Apple prints for the whole LC series and the Quadra 605.[1]
Apple's check is a measurement, not a calendar. Set a meter to the 10 V DC range, put the positive probe on the positive end of the cell and the negative probe on the negative end, and replace the cell if it reads below 3.0 V.[1] Apple publishes no replacement interval for this battery and none is given here: a cell above 3.0 V is doing its job, and one below it should come out today whatever its age.
If it has leaked
This is a lithium cell, so neutralise with bicarbonate of soda, not vinegar. Vinegar is the right treatment for an alkaline cell, whose leakage is basic. It is the wrong treatment here, and it adds water and chloride to an already corroded board. Use a paste of sodium bicarbonate and distilled water, rinse with distilled water, follow with isopropyl alcohol and dry thoroughly.
Then check the damage instead of assuming there is none:
- Inspect under magnification for traces that have gone dull, green or thin.
- Buzz out every track running away from the holder. Corrosion travels under the solder mask and does not show from above.
- Look at the underside of the board. Electrolyte wicks down through vias and comes out the other side.
Cleaning
Opening the case
- Disconnect everything.
- Remove the case screw if one is fitted. Not every machine has one.[1]
- Lift the tabs at the back of the lid and lift the top cover straight up.[1]
Inside
- Look at the underside of the board too. Both battery and capacitor electrolyte travel through vias.
Outside
- A damp microfibre cloth and mild detergent. No abrasives, no solvents โ the texture on these shells does not survive either.
The platinum-grey plastics yellow with age. The discolouration is in the body of the plastic rather than on the surface, so cleaning will not shift it; see Retrobrite for what can be done about it and what it costs in brittleness.
Fan and speaker
On the original LC the fan and speaker are a single fan/speaker assembly, held into the bottom case by a latch at each end: release one latch, lift slightly, release the other, lift the assembly out.[1] The LC II and later use a separate fan with its own cable.[1]
Apple's expansion connector carries a FAN signal, and a card that grounds it digitally raises the fan speed to improve thermal conditions inside the case.[2] A machine whose fan runs faster than you expect with a card fitted is doing what the card asked for.
Connectors and sockets
Oxidised contacts are the commonest cause of intermittent faults on a machine this age, and the cheapest to put right.
- SIMM sockets. Clean with isopropyl alcohol on a swab and reseat. Do not take an abrasive to a SIMM's gold fingers โ once you are through the plating, the base metal oxidises and then transfers to every socket the module touches.
- Expansion slot. Check for bent contacts and debris before a card goes home.
- SCSI and floppy headers. Reseat, and check the ribbon for cracked conductors where it folds.
Expansion slot
The LC's 96-pin connector supplies +5 V at 800 mA, โ5 V at 20 mA and +12 V at 200 mA, and Apple limits a card to 4 watts total however it is drawn across the three rails. Apple's warning is explicit: a card dissipating more than 4 watts may overheat and damage the computer's circuitry or make it inoperable.[2]
Those numbers are also a diagnostic. The โ5 V rail is budgeted at 20 mA at the slot precisely because it is a weak rail on this design โ it exists mainly to feed the RS-422 serial drivers โ so a failed or reversed capacitor on it pulls it down rather than destroying anything, and shows up as modem and printer-port trouble and nothing else.
Capacitors
Fifteen surface-mount electrolytics on logic board 630-0309: eight 10 ยตF 16 V, five 47 ยตF 16 V, one 100 ยตF 6.3 V and one 1 ยตF 50 V.[3] The per-designator list, the revision note about C9, the board photograph and the full procedure are on Macintosh LC Capacitor Replacement Guide.
Sound goes first on these boards, then intermittent starting, then visible residue. A leaking surface-mount electrolytic does not have to look swollen โ the usual failure is a seeped seal, and the evidence hides under the can. See Capacitor Failure Symptoms.
Floppy drive
The 1.4 MB Apple SuperDrive is direct drive. It has no belt. Advice to fit a new belt to a sluggish or non-ejecting SuperDrive is wrong: there is nothing there to replace. What these drives actually suffer is hardened grease on the head carriage and eject rails, dust in the mechanism, and dirty or worn heads.
- If the rails are stiff, re-lubricate with a silicone grease โ not white lithium grease, which gums up as it ages.
- Apple's own replacement notes: remove the dust shield, if present, before fitting a replacement SuperDrive, and replace drives like for like, auto-inject for auto-inject and manual-eject for manual-eject.[1]
Hard disk
The original SCSI mechanisms are thirty years old and the usual failures are a stuck spindle, dried head-park grease and dead controller electronics. Solid-state replacements โ BlueSCSI, ZuluSCSI, SCSI2SD โ are quieter, cooler and considerably more reliable, and they let you keep the original drive on a shelf as a spare.
Whatever you fit, get the termination right: the internal drive on these machines is the end of the bus and must be terminated, and the computer itself is always SCSI ID 7. See Macintosh HDD Maintenance.
- Take the battery out.
- Store dry and at room temperature. Not a loft, not a garage.
- Macintosh LC
- Macintosh LC Capacitor Replacement Guide
- Macintosh LC Troubleshooting
- Macintosh LC Series/ Quadra 605 Service Source
- Macintosh LC Developer Note
- Recommended Tools
- โ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 Apple Computer, Service Source: Macintosh LC Series / Quadra 605. Hosted on this wiki as File:Quadra 605.lc series.pdf; see Macintosh LC Series/ Quadra 605 Service Source. Chapters used: Specifications (Processor, Memory, I/O Interfaces, Sound and Video, Electrical, Physical), Troubleshooting (Symptom Charts), Take Apart, Additional Procedures (Battery Verification) and Exploded View.
- โ 2.0 2.1 2.2 Apple Computer, Macintosh LC Developer Note (1990). Hosted on this wiki as File:Macintosh LC Developer Note.pdf; see Macintosh LC Developer Note. Expansion connector signal list and power budget.
- โ Console5 TechWiki, Apple computer pages โ https://wiki.console5.com/wiki/Category:Computer . Secondary source: community-maintained per-designator capacitor lists compiled from physical boards. Used here for logic-board assembly numbers and per-designator capacitor lists where Console5 carries the board.
