Macintosh IIsi General Maintenance
Revision as of 21:10, 23 September 2026 by Josh (talk | contribs) (Add the board photograph as a component location map)
Macintosh IIsi logic board 820-0301-A with every electrolytic marked: eleven 47 ĀµF surface-mount parts and two 220 ĀµF axials. Source: Recap-a-Mac.
This page covers routine care for the Macintosh IIsi.
Figures below come from Apple's Service Source for the IIsi and from Apple's Macintosh IIsi Developer Note, both hosted on this wiki.[1][2]
What this machine is
Apple's specification for the Macintosh IIsi
Item Figure
Processor Motorola 68030 at 20 MHz, 32-bit internal data bus, 256-byte instruction and data caches, burst-mode RAM access, built-in MMU
Coprocessor Motorola 68882 at 20 MHz — on the optional adapter card, not on the logic board
RAM 2 MB, expandable to 17 MB
ROM 512 K
PRAM 256 bytes
Expansion One slot for either a NuBus or an 030 direct-slot card, 15 W maximum: +5 V 2.0 A, +12 V 175 mA, āˆ’12 V 150 mA
Sound Output impedance 8–600 Ī©, short-circuit protected, internal speaker disabled when a plug is inserted; four-voice wavetable synthesis and stereo sampling
Line voltage 100–240 VAC, automatically configured, 50–60 Hz
Maximum power 100 W, monitor excluded
Dimensions 4.0 Ɨ 12.4 Ɨ 14.9 in (10 Ɨ 31 Ɨ 37.2 cm), 10 lb (4.5 kg)
All of that is Apple's.[1] The odd 17 MB ceiling is not a misprint — the IIsi has 1 MB soldered to the board plus four SIMM sockets.
The FPU lives on the adapter card. Apple's specification is explicit: the 68882 is "included on the optional adapter card".[1] A IIsi with no card fitted has no floating-point unit, and pulling the logic board apart looking for an empty FPU socket is wasted effort.
The adapter card is also how the slot works. The IIsi's single slot takes either a NuBus card or an 030 direct-slot card, and which one depends on which adapter is fitted. Apple's take-apart procedure removes the adapter card, the direct-slot card and the plastic bracket as one assembly, then pulls the adapter and the card off the logic board together.[1]
Apple service part 661-1616; the logic board is 661-1615 and the fan a separate assembly, 810-6030.[1] Apple rates the machine at 100 W maximum, monitor excluded.[1]
The unit itself is a Sony APS-06M.[3] That matters when you come to recap it, because two of its capacitors are the dangerous ones:
  • C101 and C102, 220 ĀµF 250 V. These are in series across the rectified mains — that is how a universal-input supply holds off the ~340 V that 240 V mains rectifies to, on parts rated 250 V each. Replace both together with matched parts. Never fit a single capacitor in place of the pair, and do not substitute a lower voltage rating.[3][4]
  • C105, 4.7 ĀµF 400 V, also on the primary side.[3]
There is a daughtercard inside the supply carrying two surface-mount capacitors — 100 ĀµF 6.3 V and 33 ĀµF 25 V — and they leak. They are easy to miss because they are not on the main board of the supply.[4]
Full list and procedure: Macintosh IIsi Capacitor Replacement Guide.
There is no published figure of 160 W for this supply. Apple's own maximum-power specification for the machine is 100 W.[1]
Apple publishes no rail tolerance and no power-supply adjustment procedure for the Macintosh IIsi. The Service Source contains no acceptable-range table for any rail and no trimmer adjustment; every power fault in the symptom charts ends in "Replace power supply".[1] The "+5 V 4.85–5.15 V / +12 V 11.9–12.7 V" table that circulates on pages of this era is Apple's Macintosh Plus procedure — genuine there, where it uses voltage test cable 077-0135 on the external floppy port — copied onto machines it was never written for. It has been removed from this page rather than reproduced, and no substitute has been invented.
What you can do instead is compare against a known load. Each rail at the logic-board power connector should sit close to its nominal value with the machine running and should not move when a drive spins up. A rail that is visibly low, or that sags under load, points at the supply. A rail that measures as a short to ground with the supply disconnected points at the logic board.
Before you open it
You are allowed to recap this supply, and it is one of the parts most likely to have failed. Understand what is live in it first: with the cover off and the lead plugged in, the fuse, input filter, bridge rectifier and the 250 V pair sit at mains potential, and that pair holds a charge after the plug comes out. Unplug, discharge each capacitor through a 1 kĪ© / 5 W resistor, and confirm with a meter that it reads near zero before a tool goes near the primary side.
Battery
A 3.6 V lithium half-AA cell in a holder on the logic board keeps the real-time clock and parameter RAM alive with the machine unplugged.
Apple's check is a measurement, not a calendar. Set a meter to the 10 V DC range, put the positive probe on the positive end of the cell and the negative probe on the negative end, and replace the cell if it reads below 3.0 V.[1] Apple publishes no replacement interval, and none is invented here: a cell above 3.0 V is doing its job and one below it should come out today whatever its age.
3.0 V is what Apple's manual for this machine says. It is not the 2.8 V of the IIcx, IIci and Quadra 700, and not the 3.2 V of the Centris and larger Quadras. These thresholds are machine-specific and get transplanted between pages; use the one from your own machine's manual.[1]
If it has leaked
This is a lithium cell, so neutralise with bicarbonate of soda, not vinegar. Vinegar is the right treatment for alkaline leakage, which is basic; it is the wrong treatment here and it adds water and chloride to an already corroded board. Use a paste of sodium bicarbonate and distilled water, rinse with distilled water, follow with isopropyl alcohol and dry thoroughly.
Then check the damage rather than assuming there is none:
  • Inspect under magnification for traces that have gone dull, green or thin.
  • Buzz out every track running away from the holder — corrosion travels under the solder mask and does not show from above.
  • Check the underside of the board. Electrolyte wicks down through vias.
Connectors and sockets
  • SIMM sockets. Clean with isopropyl alcohol on a swab and reseat. Do not take an abrasive to a module's gold fingers — once you are through the plating, the base metal oxidises and then transfers to every socket the module touches.
  • VRAM sockets. Same treatment. Video faults that come and go when the case is knocked usually start here.
  • NuBus and PDS slots. Inspect for bent contacts and debris before a card goes home; check the card's edge fingers too.
  • ROM SIMM socket, where one is fitted. A poorly seated ROM gives a machine that chimes and does nothing else.
  • Logic-board power connector. Look for browning or a distorted housing. A discoloured power connector is a warning, not a cosmetic problem.
  • ADB, serial, SCSI and floppy connectors. Reseat; check ribbon cables for cracked conductors where they fold.
The speaker contacts
The IIsi's mono loudspeaker sits on a small assembly underneath the logic board and is reached only after the cover, adapter card, fan, power supply, hard drive and logic board have come out — Apple lists all six as preliminary steps.[1] The connection is by spring contact rather than a plug, and tarnished contacts give intermittent or absent internal sound while the headphone jack stays perfect.
That combination — headphone jack fine, internal speaker dead or cutting out — is the signature. Clean the spring contacts and the matching pads, check the springs still have tension, and make sure the assembly is seated before the board goes back.
The fan
The fan is a separate assembly. Apple's removal instruction is exactly as blunt as it sounds: grip the fan and pull up, using some force, until it snaps out.[1] It goes back the same way.
The IIsi is a quiet machine and people sometimes assume it is convection-cooled. It is not — there is a fan, and it should be turning.
Capacitors
Thirteen electrolytics on logic board 820-0301-A: eleven 47 ĀµF 16 V surface-mount and two 220 ĀµF 16 V axial.[4][3] MacDat and Console5 agree on that complement, and Recap-a-Mac's annotated photograph of the board is hosted here as File:Mac IIsi Recap Guide.jpg.
Designators and procedure: Macintosh IIsi Capacitor Replacement Guide.
Apple published no component-level capacitor data for any Macintosh of this era, so these are community readings of physical boards. Read the value off each can before you lift it.
Cleaning
Opening the case
The IIsi's cover releases with clips and latches — no tools and no screws.[1]
Inside
  • Compressed air and an anti-static brush on the logic board, the supply and the fan. Hold the fan blade still while you blow it: spinning a fan with compressed air drives it as a generator and puts a reverse voltage back down its cable.
  • Isopropyl alcohol (99 %) and a soft brush for grime, working outwards from each capacitor and from the battery holder.
  • Check the underside of the board as well as the top. Both battery and capacitor electrolyte travel through vias.
Outside
  • A damp microfibre cloth and mild detergent. No abrasives, no solvents — the texture on these shells does not survive either.
  • ADB keyboards come apart for washing: keycaps off, warm soapy water, dry them completely, then clean the contacts with isopropyl alcohol.
  • Mouse ball out, rollers scraped and wiped with isopropyl alcohol.
Heavily contaminated boards can be washed, but do it properly: distilled water, a soft brush, a thorough rinse in more distilled water, then isopropyl alcohol to displace it, then a full day drying in a warm draught with the battery out. A half-dried board fails in ways that are much harder to diagnose than the dirt was.
Floppy drive
The 1.4 MB Apple SuperDrive is direct drive. It has no belt. Advice to fit a new belt to a sluggish or non-ejecting SuperDrive — including to the auto-inject version — is wrong: there is nothing there to replace. What these drives actually suffer is hardened grease on the head carriage and eject rails, dust in the mechanism, and dirty or worn heads. On manual-inject drives a worn eject gear is a genuine and common failure.
  • Clean the heads with isopropyl alcohol on a lint-free swab, supporting the upper head arm so it is not sprung.
  • If the rails are stiff, re-lubricate with a silicone grease — not white lithium grease, which gums up as it ages.
  • If a disc will not eject, hold the mouse button down while switching the machine on to run a full eject cycle before taking anything apart.
Hard disk
  • Take the battery out.
  • Store dry and at room temperature — not a loft, not a garage.
  • If the logic board comes out, bag it anti-statically and lay it flat.
  • Nothing needs periodic running. "Power it up every few months to keep the capacitors formed" is repeated widely and supported nowhere for machines of this kind. The real hazard to a stored Macintosh is the cell in the battery holder, and removing it costs nothing.
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 Apple Computer, Service Source: Macintosh IIsi. Hosted on this wiki as File:Macintosh iisi.pdf; see Macintosh IIsi Service Source. Chapters used: Specifications, Troubleshooting, Take Apart (Fan, Adapter Card, Logic Board, Speaker), Additional Procedures (Battery Verification) and Exploded View.
  2. ↑ Apple Computer, Macintosh IIsi Developer Note (1990). Hosted on this wiki as File:Macintosh IIsi Developer Note.pdf; see Macintosh IIsi Developer Note.
  3. ↑ 3.0 3.1 3.2 3.3 Console5 TechWiki, Apple computer pages — https://wiki.console5.com/wiki/Category:Computer . Secondary source: community-maintained per-designator capacitor lists compiled from physical boards. Used here for logic-board assembly numbers and per-designator capacitor lists where Console5 carries the board.
  4. ↑ 4.0 4.1 4.2 MacDat Capacitor Reference Library, Apple section — https://macdat.net/repair/cap_reference/apple/ . Secondary source: a community-maintained capacitor reference compiled from physical boards, giving value-and-count lists and, for most boards, an annotated reference photograph. Used here for the per-board electrolytic complements quoted, which agree with Recap-a-Mac’s independently produced board photographs wherever both cover the same board.
