Macintosh LC III+ General Maintenance
Revision as of 21:10, 23 September 2026 by Josh (talk | contribs) (Add the board photograph as a component location map)
The LC III logic board, 820-0650-B. The LC III+ is a clock variant of the same family; no separate LC III+ board photograph has been published. The circled part at lower right is C22, the reversed position. Source: Recap-a-Mac.
This page covers routine care for the Macintosh LC III+, the 33 MHz version of the Macintosh LC III sold as the Performa 460, 466 and 467. The chassis, power supply, battery, take-apart procedure and logic-board family are shared with the LC III; where this page says nothing specific to the LC III+, that is because Apple's documentation says nothing specific either.
Apple does not give the LC III+ a Service Source of its own. It is covered by the Macintosh Performa 400 Series Service Source, and the shared chassis and supply data come from the LC Series / Quadra 605 manual.[1][2]
What this machine is
The LC III+ is an LC III with the clock raised from 25 to 33 MHz. Everything else in Apple's LC III specification carries over: 68030 with a 32-bit internal data bus and burst-mode RAM access, a coprocessor socket, 4 MB on board expandable to 36 MB with 80 ns or faster SIMMs, 512 K of ROM expandable to 1 MB, 512 K of VRAM upgradable to 768 K, and a 114-pin processor-direct slot.[1]
The FPU socket
Like the LC III, the LC III+ has a PGA socket for an optional Motorola 68882. Apple's slot and power specification does not state a required speed grade for the coprocessor; the sensible rule is the general one for a synchronous PGA 68882 โ€” it runs at the processor clock, so on a 33 MHz machine fit a part rated for at least 33 MHz. Align pin 1 with the chamfered corner, support the board while you press it home, and use a proper extractor to take it out.
Every "pizza box" machine in this family โ€” LC, LC II, LC III, LC III+, LC 475 and Quadra 605 โ€” takes the same power supply, which Apple lists as a single service part, 661-1733.[1] It is a universal auto-ranging switch-mode unit covering 100โ€“240 VAC, so there is no voltage selector to set wrongly and no separate 120 V and 230 V board to confuse.[1]
Apple's electrical specification
Item Figure
Line voltage 100โ€“240 VAC, automatically configured
Frequency 47โ€“63 Hz
Maximum power, LC III 30 W, monitor excluded
Note what that figure is: the machine's maximum consumption, not the supply's rating. The same 661-1733 supply is fitted to a 50 W LC and to a 26 W Quadra 605.[1]
Apple's Service Source publishes a maximum-power figure for the LC III but not a separate one for the LC III+; the 30 W LC III figure is the nearest published value and the machines share a supply.[1]
Apple publishes no rail tolerance and no power-supply adjustment procedure for this machine. The Service Source carries no acceptable-range table for the +5 V, +12 V or โˆ’5 V rails and no trimmer adjustment; every power fault in the symptom charts ends in "Replace power supply".[1] The "+5 V 4.85โ€“5.15 V / +12 V 11.9โ€“12.7 V" table that circulates on pages of this era is Apple's Macintosh Plus procedure โ€” genuine there, where it uses voltage test cable 077-0135 on the external floppy port โ€” copied onto machines it was never written for. It has been removed from this page rather than reproduced.
What you can do instead is compare against a known load. With the machine running, each rail at the logic-board power connector should sit close to its nominal value and should not move when a drive spins up. A rail that is visibly low, or that sags under load, points at the supply. A rail that measures as a short to ground with the supply disconnected points at the logic board.
Recapping it
You are allowed to open this supply โ€” tired electrolytics in it are one of the commonest reasons one of these machines will not start. Understand what is live inside first. It is fed straight from the mains, so with the cover off and the lead in, the fuse, input filter, bridge rectifier and bulk capacitor all sit at mains potential. The bulk capacitor charges to roughly the peak of the incoming waveform โ€” about 170 V on 120 V mains, about 340 V on 230 V mains โ€” and holds a useful fraction of that after the plug comes out. Unplug, wait, then measure across the bulk capacitor and confirm it reads a few volts before a tool goes near the primary side.
Apple bought this supply from several vendors and their capacitor complements differ, so read the maker's label before ordering parts. The per-variant lists are on Macintosh LC Capacitor Replacement Guide.
Removing it: disconnect the power supply cable from the logic board, release the two latches that hold the front end of the supply to the bottom case, and lift it out.[1]
PRAM battery
Apple's part is a 3.6 V lithium half-AA cell, part number 742-0011, in a clip-in holder on the logic board. It appears under that number in the exploded view Apple prints for the whole LC series and the Quadra 605.[1]
Apple's check is a measurement, not a calendar. Set a meter to the 10 V DC range, put the positive probe on the positive end of the cell and the negative probe on the negative end, and replace the cell if it reads below 3.0 V.[1] Apple publishes no replacement interval for this battery and none is given here: a cell above 3.0 V is doing its job, and one below it should come out today whatever its age.
If it has leaked
This is a lithium cell, so neutralise with bicarbonate of soda, not vinegar. Vinegar is the right treatment for an alkaline cell, whose leakage is basic. It is the wrong treatment here, and it adds water and chloride to an already corroded board. Use a paste of sodium bicarbonate and distilled water, rinse with distilled water, follow with isopropyl alcohol and dry thoroughly.
Then check the damage instead of assuming there is none:
  • Inspect under magnification for traces that have gone dull, green or thin.
  • Buzz out every track running away from the holder. Corrosion travels under the solder mask and does not show from above.
  • Look at the underside of the board. Electrolyte wicks down through vias and comes out the other side.
Cleaning
Opening the case
  1. Disconnect everything.
  2. Remove the case screw if one is fitted. Not every machine has one.[1]
  3. Lift the tabs at the back of the lid and lift the top cover straight up.[1]
Inside
  • Compressed air and an anti-static brush on the logic board, the supply and the fan. Hold the fan blade still while you blow it: spinning a fan with compressed air drives it as a generator and puts a reverse voltage back down its cable.
  • Isopropyl alcohol (99 %) and a soft brush for grime, working outwards from each capacitor and from the battery holder.
  • Look at the underside of the board too. Both battery and capacitor electrolyte travel through vias.
Outside
  • A damp microfibre cloth and mild detergent. No abrasives, no solvents โ€” the texture on these shells does not survive either.
  • ADB keyboards come apart for washing: keycaps off, warm soapy water, dry them completely, then clean the contacts with isopropyl alcohol.
  • Mouse ball out, rollers scraped and wiped with isopropyl alcohol.
The platinum-grey plastics yellow with age. The discolouration is in the body of the plastic rather than on the surface, so cleaning will not shift it; see Retrobrite for what can be done about it and what it costs in brittleness.
Fan and speaker
The fan is a separate part with its own cable to the logic board: disconnect the cable, release the plastic latches, lift the fan out.[1]
Fit it back logo side down. Apple prints this as a caution because a fan installed the other way up blows the wrong way and, in Apple's words, may damage the computer.[1] It is the classic self-inflicted fault on this chassis: the machine goes back together, runs hot, and nothing looks wrong.
When the speaker comes out, Apple's replacement note matters โ€” thread the speaker cable through the top two brackets that hold the hard drive before reconnecting it, or the cable fouls the drive.[1]
Connectors and sockets
Oxidised contacts are the commonest cause of intermittent faults on a machine this age, and the cheapest to put right.
  • SIMM sockets. Clean with isopropyl alcohol on a swab and reseat. Do not take an abrasive to a SIMM's gold fingers โ€” once you are through the plating, the base metal oxidises and then transfers to every socket the module touches.
  • VRAM sockets. Same treatment. Video faults that come and go when the case is knocked usually start here.
  • Expansion slot. Check for bent contacts and debris before a card goes home.
  • Logic-board power connector. Look for browning or a distorted housing. A discoloured power connector is a warning, not a cosmetic problem.
  • SCSI and floppy headers. Reseat, and check the ribbon for cracked conductors where it folds.
Expansion slot
The 114-pin processor-direct slot supplies +5 V at 800 mA, โˆ’5 V at 20 mA and +12 V at 165 mA, and Apple limits a card to 4 watts total however that is split across the three rails. Apple's warning is explicit: cards dissipating more than 4 watts may overheat and damage the computer's circuitry or make it inoperable, and Apple recommends that all cards ground the /FANSPEED signal to increase cooling.[2]
The โˆ’5 V budget of 20 mA is a clue as well as a limit. That rail is weak by design, exists almost solely to feed the RS-422 serial drivers, and is the rail carrying the reversed capacitor described below.
Capacitors
No capacitor list has ever been published for the LC III+ specifically. Console5, Recap-a-Mac and MacDat all cover the LC III board and none of them carries a separate LC III+ entry.[3][4] Because the LC III+ is a clock variant of the same 820-0650 family, the LC III list is the right starting point โ€” but read the values off your own board before ordering, and see Macintosh LC III+ Capacitor Replacement Guide for the state of the evidence.
The C22 warning applies here. On the LC III board the bulk capacitor on the โˆ’5 V rail is silk-screened and fitted the wrong way round, and a tantalum fitted in the printed orientation drags the rail down and can destroy itself. Check the orientation against Macintosh LC III Capacitor Replacement Guide before you fit anything at C22.
Floppy drive
The 1.4 MB Apple SuperDrive is direct drive. It has no belt. Advice to fit a new belt to a sluggish or non-ejecting SuperDrive is wrong: there is nothing there to replace. What these drives actually suffer is hardened grease on the head carriage and eject rails, dust in the mechanism, and dirty or worn heads.
  • Clean the heads with isopropyl alcohol on a lint-free swab, supporting the upper head arm so it is not sprung.
  • If the rails are stiff, re-lubricate with a silicone grease โ€” not white lithium grease, which gums up as it ages.
  • Apple's own replacement notes: remove the dust shield, if present, before fitting a replacement SuperDrive, and replace drives like for like, auto-inject for auto-inject and manual-eject for manual-eject.[1]
Hard disk
The original SCSI mechanisms are thirty years old and the usual failures are a stuck spindle, dried head-park grease and dead controller electronics. Solid-state replacements โ€” BlueSCSI, ZuluSCSI, SCSI2SD โ€” are quieter, cooler and considerably more reliable, and they let you keep the original drive on a shelf as a spare.
Whatever you fit, get the termination right: the internal drive on these machines is the end of the bus and must be terminated, and the computer itself is always SCSI ID 7. See Macintosh HDD Maintenance.
  • Take the battery out.
  • Store dry and at room temperature. Not a loft, not a garage.
  • If the logic board comes out, bag it anti-statically and lay it flat.
  • Nothing needs periodic running. "Power it up every few months to keep the capacitors formed" is repeated widely and supported nowhere for machines of this kind. The real hazard to a stored Macintosh is the cell in the battery holder, and removing it costs nothing.
  1. โ†‘ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 Apple Computer, Service Source: Macintosh LC Series / Quadra 605. Hosted on this wiki as File:Quadra 605.lc series.pdf; see Macintosh LC Series/ Quadra 605 Service Source. Chapters used: Specifications (Processor, Memory, I/O Interfaces, Sound and Video, Electrical, Physical), Troubleshooting (Symptom Charts), Take Apart, Additional Procedures (Battery Verification) and Exploded View.
  2. โ†‘ 2.0 2.1 Apple Computer, Macintosh LC III Developer Note (1993). Hosted on this wiki as File:Macintosh LC III Developer Note.pdf; see Macintosh LC III Developer Note. Table 1-16, โ€œPDS power budgetโ€, and the accompanying 4-watt warning.
  3. โ†‘ Console5 TechWiki, Apple computer pages โ€” https://wiki.console5.com/wiki/Category:Computer . Secondary source: community-maintained per-designator capacitor lists compiled from physical boards. Used here for logic-board assembly numbers and per-designator capacitor lists where Console5 carries the board.
  4. โ†‘ MacDat Capacitor Reference Library, Apple section โ€” https://macdat.net/repair/cap_reference/apple/ . Secondary source: a community-maintained capacitor reference compiled from physical boards, giving value-and-count lists and, for most boards, an annotated reference photograph. Used here for the per-board electrolytic complements quoted, which agree with Recap-a-Macโ€™s independently produced board photographs wherever both cover the same board.
